96 Tahoe All Brakes Lights On
Old Jun 3, 2008 | 12:06 AM
sergioh28's Avatar
Default 96 Tahoe All Brakes Lights On
I have a 96 2wd Tahoe. I Replaced the whole steering column including turn signal switches, airbag and steering wheel from a 97 Tahoe. When I connected the battery I noticed all 3 brakelights were on. I can shift from Park to Reverse without having to apply the brakes. I noticed that the 97 steering column had a few extra pins on the main plug than the 96 column. It also had a steering sensor at the end of the column that I took off so it can fit. Any suggestions on what I should check out first? Thanks.
Old Jun 3, 2008 | 7:46 PM
Default RE: 96 Tahoe All Brakes Lights On
Welcome to the Tahoe forum.
Someone here should be able to help you. At first blush, it sounds like some pin assignments changed from 96 to 97.
JRich_taco
Aug 31, 2013 12:16 AM
jjw
Oct 16, 2012 9:09 PM
DOBERDEWD
Dec 11, 2011 11:35 PM
Mille Racer 69
Dec 8, 2010 8:26 PM
skdevore
Aug 26, 2009 10:18 PM
