Last edit by: IB Advertising
Browse all: General Overview
- Chevrolet Silverado 1999-2006 GMT800 How to Swap Vacuum Brake Booster with Hydroboost System
Step by step instructions for do-it-yourself repairs.
97 5.7 Vortec- injectors and poppet/spider issue
Hey there, with everything you replaced I'd be willing to bet it's the PCM, if you knew someone who would let you borrow one you could find out. The reason that's my guess is I read a while back that when an injector goes bad after a while it burns out the PCM controls then the injector stays open or partly even when the engines not running. If you want to check take the upper plenium off remove an injector from the intake be careful & get a friend to switch the truck don't crank it just switch it make the fuel pump run, if any of the injectors run or trickel it's probably the PCM or ECM think there the same thing. Let me know what you find out. Sorry I didn't notice that you said the previous owner had tried a PCM but sense you replaced the spider after he tried that I would go ahead and try another PCM again it can't hurt.
have a 97 GMC Sierra extcab sb ss. Recently had a cat code for bank 2. Told cats needed to be replacec. Cleared codes and fixed cats. Then the truck started stallin like no fuel. Now it will not start, cranks just no start. While taking iff tb cover noticed gas pooling where fuel lines join fuel regulator. Can this be caused ny clogged injectors or is regulator at fault??
Well, installed the new spider fuel meter today and have the SAME problem! Small backfires, black smoke out the tailpipe when you rev it up and the RPMs are on the way down. Rough running. Missing a little bit.
Fuel pump sounds like it's working, but I don't have a fuel meter to check pressure.
Only other things I can think of are the ECM or possibly bad fuel pump!
Anyone have any other ideas? Please?
Thanks!
Thanks!
well, i'm pretty much ready to give up on this thing. It's got me beat.
Took it out for a drive because it got the power back, but was backfiring. Quit running. After a little while, it started, but now there's a knock in the engine and a squeak from the water pump.
Wonder where one can find a decent used 5.7?
The time is off . You can move the cap a small amount by just loosening the clamp on it , if that doesn’t work you are off by a tooth or more and you will need to pull the shaft up /out turn it and drop it back in. You must have a GM compatible box to set the time . You can get close enough to do what your is doing then put the machine on it to get it right it’s a must.
Matth3w
Oct 23, 2008 1:58 PM
