97 suburban ignition switch
Old Sep 27, 2008 | 10:55 PM
docta103's Avatar
Default 97 suburban ignition switch
my 97 suburban has power to all electrical systems, lights radio etc. when i try to start it the starter does not turn over. there is no power drain when I turn the key. I have already taken out the starter and had it tested & it is fine. I have been told it may be the sns safety switch, or the ignition switch. Can I get any guidance on testing these two items?
Old Sep 28, 2008 | 7:50 AM
jljbtm's Avatar
Default RE: 97 suburban ignition switch
About 2 years ago my 95 had this problem and it turned out to be the ignition switch. it seems after about 10 years of turning this switch it just wears out. It is pretty easy to replace, there are two plastic halves around the column with 3-4 screws to remove on the underside you also have to remove the lock cylinder. Once the cover is off you will see the switch and wiring.
suburban 12
Feb 15, 2014 9:58 PM
boho115
Jul 10, 2013 7:15 PM
Truck Driver Bill
HHR
Aug 11, 2011 8:48 PM
leejosepho
Oct 26, 2009 10:51 PM
jeffwest5599
Jan 6, 2008 7:33 AM
