97 tahoe heat issues
Old Dec 18, 2009 | 12:54 AM
chevy mclovin's Avatar
Default 97 tahoe heat issues
i searched and found nothing. i have a 97 tahoe which will blow air but not like it should. its very light. i dont smell coolant. on high i get crazy amounts of smoke that smell like burning wires or coolant. dont remember. in order to really get heat i gotta go fast (on low setting) anything higher than low it makes noise and smokes out the cabin. is it the blower motor. should i replace the heater core too. are they both hard time consuming parts to replace.
Old Dec 18, 2009 | 11:18 AM
dont know what was going on but i went and fiddled around with the blower motor. its only 50 bucks so i was gonna replace it. i took out glove box, rubber cover and turned it on meanwhile i found a rubber hose that connects to motor to the box behind it. reconnected and cranked it up. all is good. at least for now. see what happens later when i really need it. also i pressed the electrical connectors in which they both moved in a little. dont know if what i did made i difference or it was a freak thing but i got heat. (for now)
Old Dec 18, 2009 | 11:21 AM
myotherchevyisablazer's Avatar
nice to hear you figured it out! heat is nice in winter!
red
Old Dec 18, 2009 | 11:37 AM
SabrToothSqrl's Avatar
Default free
my car's got free heat in the summer and free A/C in the winter
Old Dec 18, 2009 | 11:39 AM
ive got one of those as well!.....i love it
Old Dec 19, 2009 | 6:27 AM
mudmaniac's Avatar
Ride of the Month
May 2009
My 87 K5 is equipped that way also, the PO tore apart the blower housing under the hood and disconnected the heater core. I installed a small electric heater so I can 4 wheel in the winter.
Old Dec 24, 2009 | 8:26 AM
now its high or nothing. guess i still have to replace the blower motor? theres no gradual change in air velocity from low to line before high. only time air really moves is on high.
Old Dec 24, 2009 | 8:50 AM
Default core
the heater core + blower motor, were fairly easy to get at on my 95... I would assume the 97 is the same...
get some pics!
Muskovin
10
Feb 27, 2020 6:45 AM
jmarkv
Jan 24, 2012 8:21 PM
thehig
Uplander
Nov 26, 2009 9:11 PM
tumark
Apr 15, 2007 12:58 PM
