97 tahoe turn signal
Welcome to the forum
Does the turn signal arm feel flimsy or loose? might be worth trying to remove the steering wheel shroud and see if you can clean up the contacts on the signal switch...
there is also a connector bundle that goes to the switch that you might try reseating...
IIf I recall you will need a specialty security star bit to remove the steering wheel shroud that you should be able to locate at your local Harbor Fright....
fishingpro77
HHR
Aug 4, 2016 12:44 AM
RomanGuzi
Oct 2, 2011 11:40 AM
