98 Suburban A/C High Side Service Valve
Old Jul 17, 2020 | 6:38 PM
ajd3rd's Avatar
Default 98 Suburban A/C High Side Service Valve
I have a leak at the high side service valve. I purchased a new valve but I'm wondering is there any trick to removing the valve. I tried two wrenches and could not loosen it. I'm on the verge of rounding it off. I was going to try a six point deep socket but I figured I better ask first.
Also, if I wind up changing the hose, how to you get to the hose below the drier near the fire wall? The suburban has the rear heat and a/c.
Thanks!
Old Jul 17, 2020 | 7:19 PM
ajd3rd's Avatar
I see my problem. The valve does not split at the nut. I'll see if I can find socket that fits the top of the valve.
Old Jul 18, 2020 | 9:01 AM
Cusser's Avatar
The service valves typically leak. A good cap has a rubber seal inside it, that makes the real seal.
Here's an issue I had with an R-12 cap recently, crack in the rubber seal.
SalMa96
Jun 4, 2017 2:49 PM
holyspatulaboy
13
Oct 11, 2013 1:53 PM
dougd
Aug 24, 2012 7:41 AM
PastorK
Mar 27, 2010 1:28 PM
bad350trk
Jun 17, 2009 11:52 PM
