98 tahoe 4wd fuse
worked fine for a day or 2 just kept blowing fuse now pops as soon as i put the fuse in any way to straight wire it up and still use switch or my own switch just want 4wd to work
Search for bulletin "#PIP3389" on the web. "If G102 and G107 are loose the TCCM and possibly the encoder motor are being used as a ground path." This could short out the encoder motor and thus shunt the current from the 4WD fuse straight to ground as soon as the key is turned to RUN.
still not working
i have tried the fuses wire was burnt fixed that now dont blow fuse but all lights even a red light and then go off and service 4wd light comes on still no 4wd
ill4na8na2
April 7th, 2024 6:50 PM
2001Suburban
August 3rd, 2015 11:28 AM
Ron Malinowski
May 29th, 2014 11:03 PM
waller2003
October 19th, 2009 9:49 PM
DianaT
November 29th, 2007 12:12 AM
