98 tahoe 4wd fuse
Old Dec 3, 2011 | 5:30 PM
jackeduphoe's Avatar
Default 98 tahoe 4wd fuse
my 98 chevy tahoe 4wd fuse keeps blowing new transfer case new transfer case motor new actuator still blowing fuse any ideas
Old Dec 4, 2011 | 4:28 PM
worked fine for a day or 2 just kept blowing fuse now pops as soon as i put the fuse in any way to straight wire it up and still use switch or my own switch just want 4wd to work
Old Dec 4, 2011 | 4:40 PM
EinST's Avatar
Search for bulletin "#PIP3389" on the web. "If G102 and G107 are loose the TCCM and possibly the encoder motor are being used as a ground path." This could short out the encoder motor and thus shunt the current from the 4WD fuse straight to ground as soon as the key is turned to RUN.
Old Dec 4, 2011 | 10:13 PM
thanks man i plan on checking it tomorrow will let everyone know what happens
Old Dec 29, 2011 | 8:13 PM
Default still not working
i have tried the fuses wire was burnt fixed that now dont blow fuse but all lights even a red light and then go off and service 4wd light comes on still no 4wd
Old Jan 2, 2012 | 3:53 PM
EinST's Avatar
You may want to take it in for service. Something is probably causing the self test to fail. Without a proper scan tool, there's no way to know what that "something" is.
ill4na8na2
Apr 7, 2024 6:50 PM
2001Suburban
Aug 3, 2015 11:28 AM
Ron Malinowski
May 29, 2014 11:03 PM
waller2003
Oct 19, 2009 9:49 PM
DianaT
Nov 29, 2007 12:12 AM
