99 suburban starting problem
Old Jan 15, 2008 | 7:49 PM
jevirag's Avatar
Default 99 suburban starting problem
I have a 99 k2500 with a 7.4 motor. When I go to start it in the morning it starts right up then I'll drive it to work.
When I go out to lunch to start it I'll have tocrankfor a little bit before itstarts. I have checked the injectors for bleed off,andit has a new fuel pressure regulator. new plugs, wires ,cap and rotor button. the fuel pump is 18 months old ( it is a ac delco pump)fuel pressure is 56 psi. The fuel pressure drops off 6 pounds in 5 minutes with the engine off.
I would appreciate any help to resolve this problem
Joe
Old Jan 16, 2008 | 1:29 PM
ZX1100F1's Avatar
Default RE: 99 suburban starting problem
Fuel pressures are within spec, are these the same pressure readings when the engine is not starting quickly?
Can we assume that a new fuel filter is installed?
Have you checked for any stored DTC's?
Such as P0338 ?
There is an updated Crankshaft Position Sensor, P/N 10456607 that addresses this condition (and several others) but it is a waste of money if code P0338 is not set.
Also could be dirty fuel injectors.
Old Jan 16, 2008 | 3:57 PM
jevirag's Avatar
There was a new fuel filter installed, and the injectors sent out to be cleaned and checked.
If there was a po338 in the dtc wouldn't it give me a check engine light?
May 3, 2017 8:06 AM
Benrock05201
Jul 2, 2014 10:54 PM
greasy1025
May 1, 2011 10:47 AM
wrstew
Jun 17, 2007 4:05 AM
