99 Suburban starts but quits
Old Jul 6, 2011 | 3:26 PM
BBQGUY's Avatar
Question 99 Suburban starts but quits
I have replaced the fuel pump and the fuel pump relay. Pump runs a few seconds at turn of the key and builds pressure mid 50psi to start and then nothing? I can cycle the key and will start again and die again.
Please Help I need the truck running
Old Jul 6, 2011 | 3:46 PM
kevinkpk's Avatar
Is the relay following the pump? As in, is the relay dropping, then picking up when you cycle the key?
Old Jul 6, 2011 | 3:56 PM
BBQGUY's Avatar
The relay was replaced new. The pump only runs the few seconds after key is turned then nothing
Old Jul 6, 2011 | 4:02 PM
kevinkpk's Avatar
New dosen't mean anything. Is the pump not operating when the relay is energized? Need to determine if it is the relay control or the pump at fault.
Old Jul 6, 2011 | 4:20 PM
BBQGUY's Avatar
Can I jump the relay or how can I test?
Old Jul 6, 2011 | 4:21 PM
BBQGUY's Avatar
It is a 5 pin relay
Old Jul 6, 2011 | 5:42 PM
kevinkpk's Avatar
You should do with the ignition switch on, feel if the realy is energizing, pull it, put it back in the socket, back and forth ect. That will determine if the relay is picked up, and running the pump. If you don't have gas, and the relay is energized, need to look elsewhere.
Old Jul 6, 2011 | 6:11 PM
BBQGUY's Avatar
Will go try that now. Where else do I look?
Old Jul 6, 2011 | 8:09 PM
kevinkpk's Avatar
If the relay is energized, I'd look first for a fuse.
sbc_421
Oct 7, 2013 12:44 AM
farr52
Oct 13, 2010 1:46 PM
Hamid
Jun 16, 2008 2:44 PM
bdassbowti
Mar 24, 2008 11:51 AM
DennisT
Aug 12, 2007 1:59 PM
