99 tahoe gas gauge
Old Mar 1, 2015 | 10:05 PM
ALLENWRENCH's Avatar
Question 99 tahoe gas gauge
99 Tahoe gas gauge jumps around from full to empty. anyone know any causes or fixes?
has new fuel pump 3 years ago hasn't worked since
Old Mar 1, 2015 | 11:20 PM
did it get a new fuel sending unit with the pump?
Old Mar 2, 2015 | 12:06 AM
Question
I got the hole thing pump and sending
Old Mar 4, 2015 | 5:53 PM
if it hasn't worked since you put the pump in; maybe the problem is the replacement sending unit. the factory method to check this is to connect a signal generator to the wiring at the tank. changing the hertz signal with change the gauge reading. if the gauge responds appropriately, you know the wiring and gauge is ok and the sending unit is bad.
Old Mar 5, 2015 | 9:39 AM
thank u ill try that
Old Mar 9, 2015 | 9:54 PM
rojeho's Avatar
same thing happened to me. I changed the fuel pump and a few months later my fuel gauge became erratic. Reads mainly empty until the tank is about half, and then it is fairly reliable until low. I use the trip odo now, I'm not going to drop the tank again to get back up to the pump/level sender or the wires.
ahearnm
Mar 19, 2023 6:37 PM
jkiff92
Mar 9, 2015 9:51 PM
wrxsubaruwrx
Dec 3, 2006 12:33 PM
pilot1996
Corvette
Jul 12, 2006 10:01 PM
