ABS is Humming with engine off
Old Oct 8, 2010 | 4:33 PM
sean804's Avatar
Default ABS is Humming with engine off
I bought a used 2001 Chevy Tahoe a few months ago. When I bought it the ABS and Brake lights were on in the insturment display. The fuse in the dashboard is fine. When I checked the fuse box under the hood, the master fuse (60 amp) was pulled. I put it back in and with the engine off it started humming (loud). I checked the dash board and the Brake light was off but the ABS light was still on. I tried starting it and it continued to hum, then turned it off and it still hummed. I pulled the fuse again to make it stop. What is it? Please help. I don't know anything about ABS systems but it almost sounds like a pump is stuck on. Does the system even have a pump?
Old Oct 8, 2010 | 11:15 PM
Welcome to the forum.
I believe there is a pump associated w/ the ABS.
Old Oct 9, 2010 | 11:45 AM
Phillips211's Avatar
your abs module is going bad, or is bad, my moms 2001 suburban did it too, we had to replace it.
Old Oct 13, 2010 | 12:31 PM
Shalooby's Avatar
Just teach it the words, it'll stop humming.
*Couldn't resist.....
preppycowboy06
Dec 24, 2012 12:13 PM
scnorris
Feb 17, 2011 7:07 AM
pearwear
Apr 1, 2008 8:53 PM
Banddingalls
Cobalt
Mar 18, 2008 8:49 PM
mwhite
Nov 18, 2007 7:01 PM
