ABS Light is on
Old Feb 26, 2010 | 7:47 PM
PastorK's Avatar
Default ABS Light is on
I tried to do a search, but the search engine won't include ABS for some reason, so it only uses light, which brings up every light in the world that has been discussed before.
My ABS light is continually on. Where should I start with this one? I have read that some wheel sensors may need to be cleaned? or that the whole control module (computer?) may be bad.
Suggestions? So far you guys have really helped me nurse this Burb back to health. I might even keep it now!!
Old Feb 26, 2010 | 9:06 PM
gotstylez's Avatar
well i'd take it somewhere so they then scan the abs autozone cant do this.. so a dealer might.. they should tell you what it is.
Old Feb 26, 2010 | 9:11 PM
vester's Avatar
The forum software will only let you search for strings > 3 characters. So to cheat use a wildcard. In this case search for:
abs* light
This is also handy when searching for 4wd.
Old Feb 26, 2010 | 9:26 PM
PastorK's Avatar
Thanks for that "Cheat Code". I try to use search before bothering everyone with a question that has already been answered.
So, and ABS scan will show which part has the issue? Wonder how much that'll cost me.
Old Feb 27, 2010 | 12:57 PM
The scan will steer you to the area that requires further diagnosis. It won't necessarily tell you what part(s) is defective.
kaptain howdie
Dec 16, 2014 8:20 PM
Bulldog9539@gmail.com
Sep 4, 2011 1:54 AM
Deteoni
Mar 28, 2009 1:39 PM
onetimeatbndcamp
Oct 10, 2006 1:16 PM
