ABS Question
Old Mar 29, 2010 | 4:50 PM
jayseidel's Avatar
Default ABS Question
I changed a leaky 4wd shaft seal today...whew, 6 hour later...during removal of the axle, i accidently stretched the abs sensor cable too far....so i disconnected it. when i put everything back together, my abs light was on...my question is, is there a reset procedure for the abs after disconnection or do you think i damaged the cable. i went in to clear a computer codes, but there isn't any codes to erase. has anyone experienced this. your help would be greatly appreciated, this is my 1st post for my 2003 5.3L 4x4 flexfuel suburban
Old Mar 29, 2010 | 9:20 PM
MDTAHOE's Avatar
Professional Mechanic
The ABS has it own computer. Most auto parts code readers will not read the ABS computer. Most ABS codes will self clear instantly when problem is gone. The wire is most likely torn in the jacket.
Old Mar 30, 2010 | 8:39 AM
jayseidel's Avatar
ok...thank you,,,while i have you here, i was wonder if you could tell me where i can find the blower resister. my fan is only working on the 5 setting. i read in a different thread that the blower resister is the culprit.
Old Mar 30, 2010 | 9:42 AM
VanGo's Avatar
You have OBD-II. You should be able to retrieve your ABS codes. My Cadillac is a '99 and it does it.
If you don't have a scanner, go to AutoZone and they will check them for free.
Scott Thompson
Mar 7, 2013 11:37 AM
Scott Thompson
Feb 24, 2013 3:52 PM
mark121268
Feb 26, 2012 12:39 AM
jerryz71
Apr 11, 2010 6:09 PM
TpnTx
Nov 15, 2008 1:52 PM
