AC Expansion Valve filter?
Replacing ac in my 2000 Suburban 2500. Removed the expansion valve to replace with new and existing expansion valve has a filter in it. New expansion valve did not come with a filter. It looks like a small orifice tube. I'm replacing the compressor, accumulator, condenser, orifice and expansion valves. I've flushed all lines. Anyone know the part number f this filter for the expansion valve? Is there something I am missing?
From the manual...
Service Information
2000 Chevrolet Chevy Suburban - 4WD | Sierra, Silverado, Suburban, Tahoe, Yukon (VIN C/K) Service Manual | HVAC | HVAC Systems - Manual | Document ID: 536021
Expansion (Orifice) Tube Description
The plastic expansion tube, with the mesh screen and orifice is in the evaporator inlet pipe. The orifice tube provides a restriction to the high-pressure liquid refrigerant in the liquid line, metering the flow of refrigerant to the evaporator as a low-pressure liquid. The filter screens on both the inlet and outlet sides protect the expansion tube and orifice from contamination. Service the tube only as a replacement assembly.
When the engine is turned OFF, after the air conditioning has been operating, the refrigerant in the system flows from the high-pressure side of the expansion tube orifice to the low-pressure side until the pressure equalizes. This is detectable as a faint hissing sound for 30-60 seconds. The hissing is normal.
When system diagnostics indicate a restricted expansion tube, replacement of the restricted expansion tube may not be necessary. Metal chips, flakes, or slivers found on the screen may be removed with compressed air. Reuse the expansion tube under the following conditions:
• The plastic frame is not broken.
• The expansion tube is not damaged or plugged.
• The screen material is not torn.
• The screen is not plugged with fine gritty material.
• An undamaged o-ring
Service Information
jerryr
18
Jun 23, 2024 12:40 PM
