Air Conditioning / Sensor Issues
Old Oct 5, 2019 | 2:57 PM
AwesomeOne's Avatar
Default Air Conditioning / Sensor Issues
I have a 2005 Suburban. I've been having issues for the past few months with the air conditioning.
While driving, the A/C compressor will shut off and start blowing hot air. This is sometimes accompanied by an odd shudder, as if the transmission isn't shifting properly. RPM issues sometimes accompany the shuddering. The check engine light comes on, and has indicated a 5-volt reference code, along with some other generic air conditioning codes. I can post codes if needed.
I've replaced the high-side pressure switch and the fuel tank pressure switch as indicated on the 5-volt system schematic. Freon has been checked and pressures are perfect. I'm a shop teacher and the auto shop teacher I work with thinks that the most likely cause of this issue is now the computer.
If the truck is turned off, sometimes the check engine light will be reset and the A/C will function normally until it starts acting up again.
Any ideas?
Old Oct 5, 2019 | 4:21 PM
oilcanhenry's Avatar
Any ideas?
I think it may well be the ECM, as you believe it is.
Old Oct 6, 2019 | 9:06 AM
AwesomeOne's Avatar
Thank you.
Is there any way I can test the ECM to see if it is indeed failing?
Old Oct 6, 2019 | 5:57 PM
Thank you.
I think you would need a professional tech with expensive tech to properly
Dx the ECM.
Old Oct 31, 2019 | 11:43 AM
SteveGranger's Avatar
An
expert can help you to fix the sensor properly.
Nikki Urmetz
Sep 3, 2019 2:07 PM
rosorio41375
Jul 22, 2016 10:28 PM
muddbug1
Aug 21, 2013 11:55 AM
06hhr
Jul 30, 2011 6:48 PM
berwin24
Jan 4, 2008 10:19 AM
