Alarm Upgrade for 2007 Tahoe
Old Jun 4, 2007 | 1:43 PM
  #11
e's Avatar
e
Default RE: Alarm Upgrade for 2007 Tahoe
Yes. However it is back on its way to us as we speak. 1701g will do full intergration of alarm and remote start into 07 GM's. BadA$$ piece.
Old Jun 10, 2007 | 3:38 PM
  #12
scott_mckinney's Avatar
Hi. Who makes this 1701g piece? How exactly does it integrate and what is so special about it?
Old Jun 10, 2007 | 6:15 PM
  #13
xclusive's Avatar
directed electronics makes the piece...it will allow the interfacethat allows thedoorlocks to work with the alarm instead of having to rewire each of the front doors in the doors and the rear doors at the bcm as well as the rear hatch...i believe the piece is now a 1701g1.
Old Jun 10, 2007 | 6:17 PM
  #14
Hi. Do you have a link to this unit online or for sale somewhere?
Old Jun 10, 2007 | 7:20 PM
  #15
e's Avatar
e
ORIGINAL: xclusive
correct DEI makes the piece. the 1701g which was pulled due to legal matters actually does full remote start interface, door locks all doors or drivers priorty than passengers, rear glass pop, rear liftgate( i havent had a chance to confirm this option). Basically you wire the alarm and r/s to the interface and it controls it thru the data bus system where as before you would have to run all of the wires to actual wiring in the vehicle. Much faster for the installer and less tapping into factory wiring.
The 1701g1 which took the place of the 1701g does not due remote start interface.
Scott I thought you wanted to upgrade or add on to your factory system?
Old Jun 10, 2007 | 9:36 PM
  #16
Hi. Well I want the best option for my vehicle. I wouldn't mind a two way pager system but they all seem too universal for the Tahoe with special options like rear lift gate and such... What exactly is included with this Directed 1701g?
Old Jun 11, 2007 | 6:16 AM
  #17
e's Avatar
e
ORIGINAL: scott_mckinney
it is a interface to be used with an alarm or remote start system. it does nothing without a unit telling it what it wants to do.
Old Jul 3, 2007 | 3:52 PM
  #18
egrigson's Avatar
So I tried to purchase the 1701G but the company indicated that it was not available but that the 1701G1 was - per the previous post this unit does not perform the same but there was an indication of a new module that was forthcoming - does anyone have any information on that new module?
Thanks!
Old Jul 3, 2007 | 6:38 PM
  #19
e's Avatar
e
ORIGINAL: egrigson
Thanks!
1701 is back. They need to update their knowledge base.We have a bunch.
1701 does full remote start INTERFACE into the 07 Tahoe's along with trunk operation (glass or autohatch) as well as doorlocks etc.
heres a list:
Tach Output
Hood Output
Factory Arm/Lock input
Remote Start Input
Factory Disarm/Unlock Driver's Door Input
Panic Input
Factory Disarm/Unlock All Doors
Glass/Hatch/Trunk Relase or Power Lift Gate Open/Close (this is a learned feature)
Remote Start Shutdown Output (12v output to brake Input on RS)
Ignition Status Output
Door Status Output
Glass/Hatch/Trunk Status Output
Bypass Output (PKIII)
The 1701G1 is pretty much the same thing minus the bypass and remote start features.
Now I know this seems very easy but the start cycle on the tahoe is pretty complex, so if your not familar with how these GM Multiplex systems work I recommended to find an Installer with the know-how. If you do not follow the start cycle properly the system can trip codes that could be only seen via the dealer. It would not show up on the dash.
Old Jul 19, 2007 | 10:18 AM
  #20
omnicube's Avatar
ORIGINAL: e
ORIGINAL: egrigson
Thanks!
heres a list:
Tach Output
Hood Output
Remote Start Input
Panic Input
Door Status Output
Just purchased an 07 tahoe as well and I am extremely interested in getting the factory alarm upgraded. With the 1701 re-released, what other DEI alarm system would go along with the module. I am mainly interested in shock and possibly glass or air pressure.
If I go to a few local installers is there anyhting I should ask for specifically as far as keeping factory options and remotes.
Thanks "e" for your insight.
