Any information on removing the heads
Old Jul 27, 2009 | 10:01 PM
Jeff.ebel's Avatar
Question Any information on removing the heads
First let me say hello to all. I am new on the the site for the second time (formally part of the Grand prix section). SO any way I am changing the gaskets and seals in the top half of the 5.7 liter engine I am down to the heads and they just don't seem to want to let go. I have all the bolts inside out as well as the ones beside the spark plug ports. am I missing something?
I have the intake off as well as the exhaust manifolds off. I am cautious to hitting them too hard due to them being alum. Any suggestions?
Jeff
Old Jul 27, 2009 | 10:13 PM
suzuki-guy's Avatar
Make sure all bolts are off before attempting this. They will be on there good they were on there really good on my truck. Do not hit them with a hammer unless your have a dead blow. Take a block of wood and hit the wood with the hammer against the head working your way around. They will take some patience.
Old Jul 28, 2009 | 5:54 AM
Jeff.ebel's Avatar
Default thanks
Yes as far as I know I have them all off. First row just below the keeers, second row in between the keepers, and the third row that sit beside each spark plug ports eight per side on that row. I'll try to use the wood again maybe give it a little more muscle.
Old Jul 28, 2009 | 6:08 AM
suzuki-guy's Avatar
Yes you have them all remember they have been torqued down and heated up for years. They will not slide off! Wack it around with a board and a hammer. To lift them I always put a bolt in the end where the accesory brackets bolt to. Good luck and be careful.
OldSchoolRider
Jan 6, 2015 7:48 PM
BetaTester
Jan 20, 2011 3:28 PM
Bc1980
Aug 7, 2009 8:36 AM
upjeeper
Apr 13, 2008 11:30 AM
garage08
Sonic (Aveo)
Nov 16, 2007 12:12 PM
