I'm Removing EGR! Any Tips? 1981 Chevy 3.8L/229 V6
Old Nov 10, 2014 | 7:42 PM
OldSchoolRider's Avatar
Talking I'm Removing EGR! Any Tips? 1981 Chevy 3.8L/229 V6
I have a 1981 Chevy El Camino and it's running like crap. I have done 90% of the tune up and I'm still experiencing a rough idle and when I hit the gas too hard, I get afterfire. Now, I know that my engine may be running either a little rich or a little lean, the timing may also need to be adjusted and all of this will be taken care of. However, I am most certainly going to remove the EGR valve and I was wondering if anyone has ever done an EGR delete on a small block Chevy and how it worked out for them. Do you have pictures? Is there anything that I need aside from a plate to block the place where the EGR valve sits?
I'm not seeking criticism for my decision. This car is emissions except!
Thanks.
Old Nov 10, 2014 | 7:48 PM
When I did my 1985 4 banger Fiero, I just used a plate over the EGR mount but I drilled a hole to allow the EGR to fit back on so everything was stock in appearance, I just didn't drill a hole for the gasses to enter back into the intake...
Old Jan 6, 2015 | 2:12 PM
oscarantolin1's Avatar
i have an 1981 el camino chevy with a 6.1 customed installed engine fuel inyected,i need to buy an instrumentation panel but i also need to know if the original panel will work with that engine? or do i need a customed panel for the 6.0 engine?
Old Jan 6, 2015 | 2:16 PM
Default chevy el camino 1981 question
Old Jan 6, 2015 | 7:48 PM
all depends on the system you bought which we have zero information about.
funnyguyMI
Dec 9, 2013 2:06 PM
sleeper79blazer
K5 Blazer
Aug 5, 2010 12:06 AM
lt1 munster
Jun 19, 2010 3:31 PM
jensenracing77@yahoo.com
Jan 11, 2010 4:03 AM
