ATF recommendation for "New" 2002
Old Feb 23, 2014 | 7:40 AM
  #11
b4hntn's Avatar
I want to thank each of you for the help. I think I will follow tech2 and do both filter and Dexron flush on the transmission.
Next question please, what lube for the rear ends in Texas heat?
Old Feb 23, 2014 | 7:59 AM
  #12
tblt44's Avatar
I use Mobile 1 75w-90 in a limited slip rear end.
florida
Old Feb 23, 2014 | 8:02 AM
  #13
Check your owners manual for recommended fluids, for the 07 and up the recommended fluid is:
Rear Axle
SAE 75W-90 Synthetic Axle
Lubricant (GM Part No. U.S. 12378261, in
Canada 10953455) meeting GM Specification 9986115
Old Feb 23, 2014 | 8:12 AM
  #14
Originally Posted by 73shark
Then when your transmission goes Tango Uniform at 100 K miles, they will tell you that you should have had it flushed.
I have had the same service adviser for some time, so I am hoping he is steering me right.... I believe Tech2 has the right recipe, exchange all the fluid, with the same flow direction and non-pulsed and you should be good....
Regular fluid and filter changes would net you nearly the same thing.... but I have known others with gmt800's that got 230k miles out of a transmission and never serviced it....
I'll setup my reminder to have the filter/fluid changed again at 130k, that will put me on a 50k service interval.... if it fails before then I let you know so you can say I told you so....
Duenas&BigBertha
Jan 21, 2012 12:29 PM
kzov21
Jan 8, 2012 8:18 PM
cs361
Jul 17, 2011 4:02 PM
Rez
Feb 20, 2010 2:56 PM
ncseahawk
Feb 15, 2010 11:18 AM
