Battery Drain '05 Suburban z71
Old Jan 22, 2016 | 6:13 PM
brandonrob23's Avatar
Default Battery Drain '05 Suburban z71
I am having an issue with the battery/starting system with this Suburban I just purchased. Obviously the dealer mistaking care of it but it's a Dodge dealer and I wanted to do some of my own research.
A new battery was installed: It started up just fine for about 6-8 hours. After it sat overnight, I went out to start it and all I got was one loud "CLICK"…coming from the starter underneath so I hit it a few times with a dead-blow and nothing happened. I proceeded to jump it from my truck and it wouldn't fire..just the same click.
The dealer came and picked it up and put a new battery in it, tested the charging system and everything came back "OK" so I took profession and again the same thing happened..it was ok for about 5-6 hours but I went out this morning and the same "CLICK" occurred. I am lost.. seems something is obviously draining it overnight. I also heard some weird noises coming from under the dash while driving last night, might be related I am not sure.
Lastly, every time I enter and exit the vehicle, the voice comes over the speakers and says "Phone Unavailable" Could this be causing a draw?
Trailer Brake maybe?
AC relay thus the dash noise?
Any advice or direction would be appreciated.. I know enough about cars to be dangerous, thats all. I want to be educated enough so they do not push me around.
Thanks in advance
Old Jan 22, 2016 | 8:15 PM
besides isolating and finding the draw...there is nothing else to be done. Are they doing this or are you on your own?
I assume you have all accessories, phone chargers cords disconnected from the outlets as they will draw power even when not connected to a device.
Old Jan 22, 2016 | 8:26 PM
Welcome to the forum.
They need to measure the quiescent current draw at the battery w/ everything off and then start pulling fuses until the current drops to zero.
Old Jan 22, 2016 | 8:32 PM
Yeah after reading on here for the last hour I have some direction. They are doing all of this for me, it left my pregnant wife stranded this morning in 8 degree weather so that didn't sit well. The dealership is taking care of everything but I want to make sure I am not going to face this same issue 2-3 months down the road. They were replacing the starter this evening and if that doesn't fix it I will suggest the fuse test/draw check. Appreciate the responses. Hope to have it fixed soon.
Old Jan 22, 2016 | 9:02 PM
Rednucleus's Avatar
Our 05 say Phone Unavailable too - has to do with Onstar not working since their upgrade.
