battery drain
i have a 02 suburban that will drain the battery if i dont start it every day. when i unplug the ctsy lp fuse under the hood it fixes my problem. im wondering if my bcm is not going to sleep and causeing this problem? or is there something else to look at? my lights was never left on and i dont just want to leave my fuse unpluged. please help!
More than likely you have a short in the ctsy circuit. Check each light one at a time. There could be a faulty switch that is allowing a partial drain without the light being on.
Hi, I am having the same problem with a 2004 Z71 suburban how did you determine it was the ctsy lp fuse?
Unfortunately when I do a draw test it only reads 10ma, which is normal. At times it would spike to 50 for less than a second and return back to 10. Dealership cannot find problem, alternator/starter both okay and I am on my third battery. Dealership also updated many modules, still no luck.
With new battery I was able to go a week driving it daily, went out Sunday - dead, no start.
Any suggestions/help appreciated, I will also try pulling this fuse to see if it makes a difference. Again I wonder if bcm is not going to sleep.
try also checking the drive belt tension. not enough tension can drain the battery. also loose terminal connections could be the culprit. i know it sounds a bit silly. but sometimes its the simple things
koverbey
December 24th, 2014 2:43 PM
