battery drain
Old Jan 28, 2014 | 8:44 AM
epadilla's Avatar
Default battery drain
i have a 02 suburban that will drain the battery if i dont start it every day. when i unplug the ctsy lp fuse under the hood it fixes my problem. im wondering if my bcm is not going to sleep and causeing this problem? or is there something else to look at? my lights was never left on and i dont just want to leave my fuse unpluged. please help!
Old Jan 28, 2014 | 10:34 AM
More than likely you have a short in the ctsy circuit. Check each light one at a time. There could be a faulty switch that is allowing a partial drain without the light being on.
Old Jan 28, 2014 | 2:18 PM
epadilla's Avatar
Thank you for the info! Will give that a try
Old Jan 28, 2014 | 7:31 PM
webby00011's Avatar
Hi, I am having the same problem with a 2004 Z71 suburban how did you determine it was the ctsy lp fuse?
Unfortunately when I do a draw test it only reads 10ma, which is normal. At times it would spike to 50 for less than a second and return back to 10. Dealership cannot find problem, alternator/starter both okay and I am on my third battery. Dealership also updated many modules, still no luck.
With new battery I was able to go a week driving it daily, went out Sunday - dead, no start.
Any suggestions/help appreciated, I will also try pulling this fuse to see if it makes a difference. Again I wonder if bcm is not going to sleep.
Old Jan 29, 2014 | 8:50 AM
trainwreck91's Avatar
try also checking the drive belt tension. not enough tension can drain the battery. also loose terminal connections could be the culprit. i know it sounds a bit silly. but sometimes its the simple things
Old Jan 30, 2014 | 12:33 PM
epadilla's Avatar
I just started pulling fuses till it drain my battery. It took a few days to find. Hope it works for you I know its frusrating as heck
bigdaddyviking67
May 14, 2019 10:38 AM
koverbey
Dec 24, 2014 2:43 PM
darrellkk
Sep 30, 2009 2:57 PM
cblu007
Mar 15, 2008 11:51 AM
birdxa
Sep 30, 2007 2:45 PM
