Both P2a01 and P2a04
Old Aug 14, 2019 | 9:22 PM
  #11
kevinkpk's Avatar
This engine came with O2 sensors, and you connected them with the original harness? At this point, clean the connectors, disconnect the battery for half hour, then go from there, IMO.
Old Aug 14, 2019 | 11:28 PM
  #12
KChevy75's Avatar
Are these new O2 sensors installed when the engine was installed or originals? I've read here that many people have had problems with certain brands of O2 sensors.
If they are original, I'd check for vacuum leaks and monitor long term fuel trim which can be used to determine if you possibly have a vacuum leak.
Old Aug 15, 2019 | 7:33 AM
  #13
ServerGuy's Avatar
Sensors did not come with the new engine, these are the downstream sensors.
Old Aug 15, 2019 | 2:09 PM
  #14
ServerGuy's Avatar
Originally Posted by ServerGuy
Connections looked good, while normal driving both sensors in question would range between .3 and .8V with an average of .4v
One the code pops again I'll read it at that time and update
Light kicked on and I could see at least one sensor bouncing between 0 and 1.3v. I have a single sensor coming in and will replace one of them to see if one code stops appearing.
Old Aug 20, 2019 | 10:39 AM
  #15
ServerGuy's Avatar
Update:
I ordered a single O2 sensor to replace the driver side downstream sensor. Waited for the light to kick on and only a single code comes back for the passenger side O2 sensor. Ive ordered a second sensor and will replace it as well.
Just odd that they both kicked the bucket at the same time. If I have either die again I will update but it seems like 2 bad sensors.
blkfleet73
Dec 27, 2018 5:52 PM
Jon O.
Dec 5, 2017 9:07 PM
dougx
Nov 9, 2015 1:45 AM
aubiexx
Nov 26, 2012 7:29 PM
jleone
May 21, 2008 10:31 PM
