brake promblem
Old Apr 1, 2008 | 5:25 PM
mikieuscg's Avatar
Default brake promblem
Ihave an 03 tahoe. The parking brake light is staying on (without parking brake engaged) and on start up message center displays service brake system. There is also a small pump located under the driver side door that will not stop running so i pulled the plug to turn it off.I am thinking that it is a boost pump?? Does anybody have any ideas? thanks for the help
Old Apr 1, 2008 | 6:22 PM
ZX1100F1's Avatar
Default RE: brake promblem
The motor is call the Supplemental Brake Assist (SBA) motor, replace it with an updated motor GM part #89040236 to correct that problem.
Does your park brake work correctly other then the light remaining on?
Old Apr 1, 2008 | 6:47 PM
mikieuscg's Avatar
Not really parking brake is kinda loose. but i thought that was just bacause of the lift and tires i am running.... so that pump just went bad?
Old Apr 2, 2008 | 6:46 PM
mikieuscg's Avatar
could it also be a sensor some where that could have went bad?
Old Apr 5, 2008 | 7:11 PM
mikieuscg's Avatar
i went to the chevy dealership. and they told me that it was the abs motor? do you know anything about that?
Old Dec 13, 2009 | 8:21 AM
n2snow2's Avatar
im having the same problem the abs pump running when key off help
Old Dec 13, 2009 | 8:22 AM
n2snow2's Avatar
please
skins92
Oct 21, 2012 6:21 PM
mikieuscg
Feb 14, 2008 8:04 PM
mikieuscg
Feb 7, 2008 9:46 AM
cooter
Apr 19, 2007 6:58 PM
