Broken Exterior Door Handles
Old Mar 2, 2011 | 11:06 AM
rjj's Avatar
rjj
Default Broken Exterior Door Handles
I recently purchased a used 2007 Suburban LTZ. This weekend, both passenger side exterior door handles pulled away from the body. Is this common? I took it to the dealer, and they want $165.00 a piece to replace them. The car is out of factory warranty, but it seems to me that they would replace these at no cost on a vehicle that cost $60K new.
Old Mar 2, 2011 | 12:14 PM
Welcome to the forum...
the outside handles are not near as common as some other issues... did the handle just pull out or is it broken? it could be an issue of the cold weather causing things to shrink up....
I think someone had just posted a similar issue in the forum a month or so back so a search might give some more info... but as the day goes on others with start to chime in....
Old Mar 2, 2011 | 1:04 PM
I've heard that they're susceptible to break-in as they aren't very substantial but haven't heard of them just breaking under normal use.
Old Mar 2, 2011 | 7:12 PM
jmzvet's Avatar
4 new chrome handles cost about $100 and 2 hours to install. $160 a piece seems a bit high!
Old Mar 2, 2011 | 9:22 PM
MDTAHOE's Avatar
Professional Mechanic
TECHNICAL
Bulletin No.: 09-08-64-032
Date: September 25, 2009
Subject: Chrome Outside Door Handle Loose/Cracked at Attachment Screw (Replace Handle)
Models:
2007-2008 Cadillac Escalade, Escalade ESV, Escalade EXT
2007-2008 Chevrolet Avalanche, Silverado, Suburban, Tahoe
2007-2008 GMC Sierra, Yukon, Yukon XL, Yukon Denali, Yukon Denali XL
Condition
Some customers may comment that a chrome outside door handle is loose or cracked in the area of the attachment screws.
Cause
This condition may be caused by grease used on the attachment screws during the assembly process, which can migrate into the handle screw bosses and cause degradation. Another contributing factor to this condition is that the initial assembly torque of the attachment screws was too high, which may have helped initiate cracks in the screw bosses.
Correction
Important
When replacing a chrome outside door handle for this condition, be sure to address the following: - Ensure that the attachment screws are free from grease before installing the new handle. Clean the screws with Kent Automotive Acrysol(TM), or an equivalent grease removing body solvent.
- Torque the screws to 6 Nm (53 lb-in).
Replace the affected chrome outside door handle. Refer to Front Side Door Outside Handle Replacement, Rear Side Door Outside Handle Replacement, or Rear Side Door Outside Handle Replacement (Crew Cab) in SI.
Parts Information
Acrysol(TM) is available from Kent Automotive at 1-888-YES-KENT or online at www.kent-automotive.com.
Old Mar 22, 2011 | 10:47 PM
Double Aught's Avatar
Dude, you are made of money and hopefully when you are taking off a door panel, nothing sounds like it broke!
Old Sep 28, 2011 | 9:30 PM
Seabass8's Avatar
Default 2007 suburban door handles
My 2007 suburban LTZ now has three of four broken exterior door handles.
I have searched everywhere, and this problem is common it seems.
Door handle connects to the door via PLASTIC threaded rod and nut. Engineering defect that chevy needs to recall, but so far they will not.
$50,000 vehicle, 4 years old, with what is clearly a defect, and they will not step up to the plate. Keep complaining. $150-$200 each door seems to be the going repair cost.
Old Oct 5, 2011 | 11:59 AM
Faceplant's Avatar
So there is a TSB on it apparently ^^^. Does this mean the dealers will replace if you are under an extended warranty?? My drivers door handle pulled away from the front this week. Unreal.
Old Oct 5, 2011 | 6:15 PM
Faceplant, welcome to the forum...
If you have GMPP it may be covered, your dealer of choice will be able to tell you that for sure...
If you call them they may say no, if you take it in you may get a difference answer...
Old Oct 6, 2011 | 6:49 AM
MDTAHOE's Avatar
The will if the chrome is comming off or is sharp.
