Broken off rear window defroster connection
Old Aug 7, 2016 | 1:22 PM
  #11
Typerod's Avatar
15 Year Member
Thank you!
Old Aug 8, 2016 | 9:26 PM
  #12
fishing nut's Avatar
I used the permetex rear window repair kit with good luck. You need to follow the directions and they have a you tube link for it. It lasted three years and now my 3yr old ripped it off, so I need to repair it again.
Old Aug 9, 2016 | 6:53 PM
  #13
Typerod's Avatar
15 Year Member
Thanks for your reply! I'm going to order the permatex kit and try it out. I'll report back when I have finished. I wonder how will I know if the connection is working? My back window is tinted, so I don't thnk I can use my multimeter to check continuity etc.
Old Aug 9, 2016 | 10:29 PM
  #14
cleveland63b's Avatar
turn the defrost on and see if the glass feels warm or use a temp gun
Old Aug 10, 2016 | 7:37 AM
  #15
Typerod's Avatar
15 Year Member
will do, thanks! I have an IR thermometer that i'll use.
Old Dec 17, 2016 | 5:42 PM
  #16
Typerod's Avatar
15 Year Member
Just an update, today we had ice on the windows from an overnight freezing rain session, and sad to say the defroster isn't working, so the fix I applied back in august did not work. I may just end up replacing the rear glass...
Old Dec 18, 2016 | 4:55 PM
  #17
intheburbs's Avatar
Well, as they say on another forum I frequent, "pepper your angus." Rear glass is expensive. I seem to recall I got a quote of like $800.
Old Dec 19, 2016 | 2:48 PM
  #18
Typerod's Avatar
15 Year Member
I see brand new in box rear windows on Ebay for ~ $450 shipped, I can probably do the install myself, I believe its all bolt on.
Old Dec 29, 2021 | 7:01 PM
  #19
01S10AD's Avatar
Hey guys. My 07 suburban has two connections one on each side of the glass. My passenger side connector to glass fell off. I do have voltage going to it. My driver side is good but no voltage. Is voltage required on both sides to defrost ot just one?
Old Dec 29, 2021 | 7:32 PM
  #20
-power just one side. the other side should go to grd.
