Buying 2003 Sub - what to look for
Old Feb 20, 2015 | 12:48 PM
crkranz's Avatar
Default Buying 2003 Sub - what to look for
I'm looking at buying a nice 2003 Sub z71 with 160k. Is there anything specific I should look at when I go inspect and test drive it?
Old Feb 21, 2015 | 11:05 AM
See if there are any maintenance records. Knowing if the truck was well cared for is important. Oil and filter regular changes are very important.
Old Feb 22, 2015 | 8:42 PM
dtimmerman's Avatar
I own a '04 Suburban z71. Bought it in 2012 with 140k; it now has 184k. It has been a great vehicle.
I agree, make sure to check the maintenance records. If the vehicle has been taken care of then it will last a long time.
Check to see if the fuel pump has been changed; they tend to go out between 100k - 150k. I had a '94 burb that blew it's pump on the highway.
With this one I change the pump myself last June just as a precaution. It was the original pump.
One of the biggest headaches on these are the knock sensors; I replaced them as well. They get moisture in them and rust out.
But overall; like "oldchevy" said; check to see if it was well cared for.
Old Feb 22, 2015 | 8:59 PM
Bluewhale's Avatar
If you are in northern/snowy areas of the country, I'd look at the brake lines.
scottji
Apr 11, 2013 11:15 AM
Lgdude77
K5 Blazer
Sep 13, 2012 12:33 PM
TxLTZz71
Mar 2, 2012 8:48 PM
Strahan
Aug 28, 2011 12:24 PM
Jasontamu
Jul 17, 2007 5:26 PM
