Cams and misc P/N needed please
Old Oct 22, 2021 | 12:38 PM
kidd101proof's Avatar
Default Cams and misc P/N needed please
Need to tow more (9-10k) in the wifes 2014 tahoe 2wd, has max cooling, 3.42's. I want to stockpile all parts and do the work all at once. Needing advice on parts.
Cam- wanting an "rv type" Don't want to swap convertor
headers
3.73
Intake? Do I need this?
port and polish? do I need this?
Just looking for advice and part numbers, I'll be installing helper bags, cold air intake and a controller as well.
Thanks in advance, go gentle i'm new to this forum stuff
Old Oct 23, 2021 | 9:06 AM
repairman54's Avatar
At those tow weights you need more brakes and heavier axles rather than engine power.
Your in 2500 series territory not 1500 series trucks. Tahoe's are only 1/2 ton 1500 trucks with about a 7500 GVW rating. You need at least a 2500 series suburban or pickup to tow that weight safely.
Better to put the money and time into a bigger truck.
Old Oct 23, 2021 | 10:25 AM
correctly set the trailer brake control and it will help stop the truck. My camper is literally 8100 lbs, on these flat Louisiana roads a 1500 is fine. We just use it for travel ball around the gulf coast, no climbing uphills or braking downhill
Bryan Doc Carpenter
Sep 23, 2015 1:24 AM
snowman4839
Jan 17, 2013 10:45 AM
Trosetti
Dec 28, 2012 6:25 PM
afentonchev
Silverado DIY and Useful Threads
Jan 4, 2010 10:16 PM
