Cargo dimensions, help please.
Old Jan 18, 2011 | 7:18 PM
RAM_Designs's Avatar
Default Cargo dimensions, help please.
I'm starting a web site that provides subwoofer enclosure plans for various vehicles at an affordable price. These would be for people to build their own boxes. I'm doing this so they don't have to sacrifice quality by going with a pre-fab box, or money by going with a custom box from Car Toys or something of the like. I'm wanting the Tahoe/Yukon/Suburban to be in there because I know it's a very popular vehicle that has some good room to work with in the cargo area, if the third row seat(s) is taken out.
Now, I know my friend's '03 Tahoe has 48" between the wheel wells and about 19-20" tall up to the window line. The question is, are all Tahoes/Yukons/Suburbans of that generation the same as far as wheel well clearance goes? Also, would 48" wide and 19-20" tall still be usable in the previous generation in the mid-late 90's as well as the current model version from '07 and up?
Thanks for any and all help,
-Ryan
Old Jan 20, 2011 | 1:02 PM
bump...
Old Jan 20, 2011 | 1:03 PM
I'm betting your best bet is to go to a car lot and start measuring....
Old Jan 20, 2011 | 1:43 PM
True, but I figured someone on here could easily measure the space between their wheels wells and give me a general height limit that wouldn't go over the rear seats.
Old Jan 20, 2011 | 2:23 PM
SabrToothSqrl's Avatar
Default wheels
most vehicles strive for 48" between the wheel wells, so you can carry drywall or plywood.
i'm 95% sure the GMT900 is 48" between the wheel wells.
Old Jan 20, 2011 | 9:26 PM
About 48.25" actually.
Old Jan 21, 2011 | 6:15 AM
That's for your '07 and '10 Tahoe? I assume that same 48.25 would work for the Suburban and Yukon as well?
Old Jan 21, 2011 | 7:08 AM
Google is your friend....this is for all GMT900 vehicles
Tahoe
http://www.chevrolet.com/vehicles/20...on/features.do
Dimensions 1HY
Overall Length 202.0 in
Overall Width 79.0 in
Overall Height 74.6 in
Wheelbase 116.0 in
Front Head Room 41.1 in
Second Row Head Room 34.1 in
Third Row Head Room 37.9 in
Third Row Shoulder Room 61.7 in
Third Row Hip Room 49.1 in
Third Row Leg Room 25.6 in
Front Hip Room 64.4 in
Second Row Hip Room 60.6 in
Front Leg Room 41.3 in
Second Row Leg Room 39.0 in
Front Shoulder Room 65.3 in
Second Row Shoulder Room 65.2 in
Seating Capacity 8
Cargo Volume 108.9 ft³
Ground To Top Of Rear Load Floor 32.3 in
Ground Clearance, Front 10.2 in
Ground Clearance, Rear 9.5 in
Curb Weight 5700.00
Gross Vehicle Weight Rating (GVWR) 7100.00 lbs
Gross Combined Weight Rating (GCWR) 12000 lbs
Maximum Payload 1471.00 lbs
Axle Capacity - Front 3400 lbs
Axle Capacity - Rear 4200 lbs
Suburban
Dimensions LS LT LTZ
Overall Length 222.4 in 222.4 in 222.4 in
Overall Width 79.1 in 79.1 in 79.1 in
Overall Height 76.8 in 76.8 in 76.8 in
Wheelbase 130.0 in 130.0 in 130.0 in
Front Head Room 41.1 in 41.1 in 41.1 in
Second Row Head Room 38.5 in 38.5 in 38.5 in
Third Row Head Room 38.1 in 38.1 in 38.1 in
Third Row Shoulder Room 64.7 in 64.7 in 64.7 in
Third Row Hip Room 49.4 in 49.4 in 49.4 in
Third Row Leg Room 34.9 in 34.9 in 34.9 in
Front Hip Room 64.4 in 64.4 in 64.4 in
Second Row Hip Room 61.8 in 61.8 in 61.8 in
Front Leg Room 41.3 in 41.3 in 41.3 in
Second Row Leg Room 39.5 in 39.5 in 39.5 in
Front Shoulder Room 65.3 in 65.3 in 65.3 in
Second Row Shoulder Room 65.2 in 65.2 in 65.2 in
Seating Capacity 9 8 7
Cargo Volume 137.4 ft³ 137.4 ft³ 137.4 ft³
Inside Bed Width, Between Wheelhousing 49.1 in 49.1 in 49.1 in
Ground To Top Of Rear Load Floor 32.6 in 32.6 in 32.6 in
Ground Clearance, Front 10.5 in 10.5 in 10.5 in
Ground Clearance, Rear 9.1 in 9.1 in 9.1 in
Curb Weight 6016.00 6082.00 6233.00
Gross Vehicle Weight Rating (GVWR) 7400.00 lbs 7400.00 lbs 7400.00 lbs
Gross Combined Weight Rating (GCWR) 11500 lbs 11500 lbs 11500 lbs
Maximum Payload 1376.00 lbs 1376.00 lbs 1376.00 lbs
Axle Capacity - Front 3925 lbs 3925 lbs 3925 lbs
Axle Capacity - Rear 4200 lbs 4200 lbs 4200 lbs
Old Jan 21, 2011 | 1:34 PM
Never assume. Notice that the third row hip room is different on the Tahoe and 'burb and 'burb says 49.1" inside wheel well. I've never measured mine and since it's about 15* outside, probably won't but don't remember that there was over an inch clearance when hauling 48" mat'ls.
907AK
Mar 6, 2026 2:13 AM
EvansBlue
S10 & Blazer DIY and Useful Threads
10
Aug 12, 2016 9:24 PM
cams 98 silverado
Mar 9, 2008 5:06 PM
Dmoney6
Sep 28, 2006 9:33 PM
