changed head gaskets, wont start
Old Feb 27, 2010 | 10:48 PM
craazyfool's Avatar
Default changed head gaskets, wont start
hey all, i recently changed the head gaskets on my 97 suburban, now it wont start, my guess would be the ignition timing which im going to look into tomorrow, but wondering if anybody else has run into this problem and maybe had a quick tip...
thanks
Old Feb 27, 2010 | 11:13 PM
maxxman04's Avatar
make sure your distributor was installed correctly. check this link for procedure if unsure. also double check all connections, valve adjustment.
http://www.truckforum.org/forums/gmc...-question.html
maxxman04's Avatar
oh yeah, welcome to our forums.
Old Feb 28, 2010 | 5:08 PM
craazyfool's Avatar
thanks maxx, ignition was my problem, that link was a big help, except the part where it talks about lining up the tabs on the shaft with the paint mark and then lining up the rotor to the mark, which is impossible to do since they are linked and two different locations if that makes any sense...
well she runs now but now the oil gauge is reading 0, suspecting the oil sending unit is disconnected or malfunctioning due to carelessness while playing with other stuff ;p
snowing now so will have to take a break for a couple days
projectman69
Camaro
May 19, 2010 11:58 PM
97RedBull
Mar 4, 2010 8:42 PM
craazyfool
Mar 1, 2010 10:21 PM
mjs182004
Oct 17, 2008 11:56 AM
