Check engine light code P0449
Old Aug 8, 2008 | 5:41 PM
07tahoe's Avatar
Default Check engine light code P0449
check engine light ison,autozone says code is P0449 this is whattheir ticket says:
The PCM has determined that a malfunction exists in the electrical circuit for the vent valve/solenoid in the evaporative emission control system.
Definition:
EVAP (Evaporative Emission System) purge/vent solenoid circuit condition
Explanation:
The solenoids and system wiring are monitored for opens or shorts
Probable Causes
1- Purge or vent solenoids defective
2- Check connevtor and wiring
3- Fuel saturated vapor canister
4- Failed EVAP vent solenoid
any info and help is appreciated.
Old Aug 8, 2008 | 8:31 PM
Default RE: Check engine light code P0449
the connector its refering to
if you spend any money or your Tahoe spend it on the factory service manual!
Old Aug 14, 2008 | 5:23 PM
07tahoe's Avatar
Turned out to be the vent solenoid valve, 30 bucks at the dealer and i installed it in 10 minutes, thanks in2pro for the info [/align]
Old Aug 15, 2008 | 7:28 AM
No problem glad to have helped, were the images any help?
Old Feb 21, 2010 | 9:41 AM
biged412's Avatar
Default location of evap solenoid
What is the general location if the soliniod ? THANKS
Old Feb 21, 2010 | 3:46 PM
Welcome to the forum. I think it's up around the tank filler tube.
Old May 14, 2010 | 10:21 AM
marine02xx@yahoo.com's Avatar
If you have a Tahoe, it will likely be attached ot the EVAP canister near your gas tank. I have attached a few images that should help you locate it:
EVAP Canister Vent Valve (2005 Chevy Tahoe)
Service Manual's description of EVAP System
Hope this helps!!
marine02xx
Old May 24, 2010 | 6:45 PM
4HANDSDC's Avatar
Default p0449
Could this sensor have any thing to do with rough idle. Or hard starting. Making the engine die at idle intermittently.
Chris
Old May 24, 2010 | 6:55 PM
I doubt it since it is in the evap. emission loop. Could be dirty injectors, dirty throttle body, dirty idle air control. Try running a couple of bottles of Techron thru it.
Old Jul 6, 2010 | 8:06 AM
fschlenter911's Avatar
Default On Track - ?? P0449
Guys,
I have looked at the threads and wanted to ask for your help! I have a Chevy Avalanche 2007 with the P0449. Looks like it is either a gas cap ($35) at Pohanka Chevrolet (not likely), or the EVAP Canister Vent Valve ($42). Both in stock. They do not have a manual but highlighted Helm Inc. adn 1-800-782-4356 to get it.
anyway, I will inspect the gas cap. Should I replace it either way. In other words, can there be a problem that's not visible.
I am not a mechanic by any means. Is the EVAP Canister Vent Valve easy to replace?
thanks and nice forum.
