Code PO121 2007 Suburban
Old Nov 3, 2010 | 2:41 PM
jkj860's Avatar
Question Code PO121 2007 Suburban
Check engine light is on and it runs rough (hesitation) at speeds around 30/40 mph. Is this the throttle position sensor and is it something I could change out myself? I don't have a warranty as I bought the truck used. I'm just trying to save some money by doing it myself. Any tips?
Old Nov 3, 2010 | 8:01 PM
have you tried any of the suggestions for the code P0121?
yes it is something you could probably do some basic troubleshooting on...
A code P0121 may mean that one or more of the following has happened:
TPS has intermittent open or short internally
Harness is rubbing and causing an open or short in the wiring
Bad connection at the TPS
Bad PCM (less likely)
Water or corrosion in connector or sensor
http://www.obd-codes.com/p0121
Old Jan 29, 2015 | 3:32 PM
FireMedic08's Avatar
A little automotive electrical grease might do the trick as that fixed my problem after replacing the TPS.
Old Jan 31, 2015 | 10:47 PM
titantn24's Avatar
Default You can do it!
Check my posts here: https://chevroletforum.com/forum/tah...e-39344/page4/
Should cover all you need to know.
moespeeds
Nov 15, 2016 3:34 PM
Bassman780
Aug 20, 2016 4:35 PM
bfd811
Mar 24, 2014 9:12 PM
dcoperator
Nov 16, 2013 11:03 AM
mudslide
Avalanche
Feb 21, 2012 3:18 PM
