Old Jul 24, 2015, 4:44 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Engine and Powertrian
Print Wikipost
Coolant fluid change
Old Oct 31, 2012 | 4:13 PM
rickp's Avatar
Default Coolant fluid change
Hey guys,
I'm planning on changing my radiator fluid as soon as my DEI Radiator Relief gets here. I spoke to one of their reps and he suggested I also add a water pump lubricant, so I'm wondering what product you guys recommend for that?
Thanks in advance for any feedback.
R.
Old Oct 31, 2012 | 4:49 PM
67Motorcat's Avatar
I have always trusted good ole' glycol (Prestone) type antifreeze.
Loose the DEXCOOL with a through flush.No need for expensive additives with regular maintenance.
Never had a cooling system issue with the "green" stuff in over 30 years unlike lots of people using the "red" stuff.
Just need to change it more often which is a good idea anyway.Cooling systems are arguably the most neglected system in vehicles today.
Old Oct 31, 2012 | 5:11 PM
rickp's Avatar
Well, I was actually going to go with the DEI Radiator relief and destilled water. I've read and heard some good stuff about it. I wanted to get some more info on it so I called the manufacturer and he suggested using a water pump lube just to play it safe.
Old Oct 31, 2012 | 9:22 PM
MDTAHOE's Avatar
Professional Mechanic
Use the water pump lube they recommend
Old Oct 31, 2012 | 10:06 PM
rickp's Avatar
they didn't, hence this question here. Sorry for the ignorance guys, but i'm just getting into this.
Old Nov 1, 2012 | 8:58 PM
I just changed the coolant in my 07 and replaced it with a 50/50 pre mix of dex-cool, it was 5 yrs old. I found no issues with the fittings, all clean and pit free... my parts person tells me that people that have had problems with dex-cool, are having it because it turns acidic if its allowed to get too hot from getting low. ( poor maintenance)
I did not add any other conditioners
Old Nov 3, 2012 | 4:34 PM
67Motorcat's Avatar
Agreed,some people will have no issues with Dex-Cool, others will.
One thing to keep in mind though is if your buy the "50/50 Mix",whether Green or Red,you are buying 50% that is just water.
The greatest marketing ploy on earth.Then when you add a bit if water to top it off you are below 50/50....
I would advise to not waste money on pre-mixed antifreeze and buy a gallon of distilled water instead if you want to spend money on water.
Of course that is just my opinion .
Old Nov 3, 2012 | 5:37 PM
I opted for the premix because I wasn't fully flushing only replacing what came out when the hoses were removed. I didn't know how much I was going to need so the premix was best option for me..
Old Nov 3, 2012 | 6:06 PM
kevinkpk's Avatar
I think what 67 was refering to wasn't the need for water 50/50 mix per say, but if the antifreeze is the same price for 50/50 and full concentrate buy the concentrate. I went back two years ago in my 2000 suburban with dexcool after a flush. Lumina specs dexcool for it. I got it used, had glycol, flushed it, replaced ALL hoses, went back with glycol (green). Mazda I think uses dexcool also, it is time for it to also get a flushing hopefully before the (my predicition) of a hard midwest winter.
Old Nov 29, 2012 | 4:26 PM
rickp's Avatar
Hey guys,
I'm due to flush and replace the coolant on my 02 Tahoe LT 5.3L.
In the manual it says to remove the cylinder block plugs and drain the coolant. Here's my question, I've looked all over the bottom of that engine and I can't find any cylinder plug. Could it be possible that my truck doesn't have them. As per the book there's supposed to be 2 of them, one on each side.
If I dont' have them, what i was planning on doing to flush the system was to drain the radiator by the drain plug, then disconnect the main radiator hose, stick the water hose in the radiator turn the water and engine on, put the heater on high and let everything flush out. Am I on track here?
Thanks guys.
R.
