Crank no start
Old Jan 29, 2024 | 1:08 PM
Firemanjoek's Avatar
Default Crank no start
07 sub ltz 5.3 flex, 266,000 miles, ran fine Friday but wouldn’t start Saturday, Sunday or today(Monday), sprayed starter fluid in the intake still no start, pretty sure I have spark, check some grounds and believe that’s not the problem, initially though fuel pump at this mileage but had son crank engine and I pushed the fuel rail valve and had fuel coming out of it, changed the crank shaft position sensor and no change, could not having adequate fuel pressure make no start even if I have a 2” spray coming out of fuel rail? Will I have pressure with just the key on so I can check fuel pressure?
Old Jan 29, 2024 | 2:38 PM
Is the check engine light on? If so, what is the code?
Todd Fuller
Apr 1, 2024 6:16 PM
Matthewe
Dec 14, 2019 8:18 PM
ctlogistics
Jan 19, 2015 12:30 PM
certifieddude
Jul 30, 2013 9:15 PM
holyearth
Nov 10, 2009 7:09 AM
