Day Time Running lights
Hello, I just joined today and I happy to be here!!!
I just bought a 1996 Tahoe with 67,000 mile on the ticker and would like to know how to get the day time running light to not come on when I turn the key on. I know if you click the e-brake but I want them to be off permanently. Is there anyway to do this?
Thanks for your help!
Jason
Jason
why would you, most likely you will get a ticket....it is law in most everywehre now....that is why they are there....a 1996 dont fall in the grandfather clause....as in it has them factory,
ORIGINAL: SWRidin
Put in burnt out bulbs. Or just remove the drl bulbs if you dont want them.
Not sure about the 96 or 97 models, but on the 98 models, there is a fuse for the DRL curcuit. Nothing else is on that fuse. Remove it and the lights don't light up.
ORIGINAL: RonH
ORIGINAL: GIXXER
I don't believe there is a switch...but if you click on the e/brake one notch they'll go off.
ORIGINAL: Bringdanoisemik1
Removing the DRL fuse on the 97 will disable the daytime lights but it will also disable the dash/guage lights, this may also apply to the 96, dont know about the 98.
Just curious why you are wanting to run in stealth mode. Daytime running lights are really not a bad thing.
