Day Time Running lights
Old Sep 12, 2007 | 1:56 PM
SFD33's Avatar
Default Day Time Running lights
Hello, I just joined today and I happy to be here!!!
I just bought a 1996 Tahoe with 67,000 mile on the ticker and would like to know how to get the day time running light to not come on when I turn the key on. I know if you click the e-brake but I want them to be off permanently. Is there anyway to do this?
Thanks for your help!
Jason
Old Sep 12, 2007 | 4:37 PM
SWRidin's Avatar
Default RE: Day Time Running lights
Put in burnt out bulbs. Or just remove the drl bulbs if you dont want them.
Old Sep 12, 2007 | 5:40 PM
MalibuMaxxSS's Avatar
why would you, most likely you will get a ticket....it is law in most everywehre now....that is why they are there....a 1996 dont fall in the grandfather clause....as in it has them factory,
Old Sep 12, 2007 | 10:36 PM
Bringdanoisemik1's Avatar
ORIGINAL: SWRidin
You cant put in burnt out bulbs, nor remove them, If you do this you will have no lights at all. I have a 97 Hoe and I would like to do the same, I dont think there is a law against this, I see many cars without daylight lights. If anyone has an answer please post.
Old Sep 12, 2007 | 11:16 PM
RonH's Avatar
Not sure about the 96 or 97 models, but on the 98 models, there is a fuse for the DRL curcuit. Nothing else is on that fuse. Remove it and the lights don't light up.
Old Sep 12, 2007 | 11:44 PM
ORIGINAL: RonH
Removing the DRL fuse on the 97 will disable the daytime lights but it will also disable the dash/guage lights, this may also apply to the 96, dont know about the 98.
Old Sep 13, 2007 | 12:07 AM
If it was against the law, then GM wouldn't have a switch that allows you to turn them off.
Old Sep 13, 2007 | 12:18 AM
GIXXER's Avatar
I don't believe there is a switch...but if you click on the e/brake one notch they'll go off.
Old Sep 13, 2007 | 1:18 AM
ORIGINAL: GIXXER
Thats what my brother does on his Hoe, I guess this is the only way to go, unless someone has a diff suggestion?
Old Sep 13, 2007 | 8:38 AM
RonH's Avatar
ORIGINAL: Bringdanoisemik1
Well then, there's also a drl relay and probably a drl module in the circuit. I don't believe those have any other function.
Just curious why you are wanting to run in stealth mode. Daytime running lights are really not a bad thing.
