Delphi fuel pump for 2001 suburban 6.0 wiring diagram update
Old Jul 30, 2022 | 10:10 PM
Philgav's Avatar
Default Delphi fuel pump for 2001 suburban 6.0 wiring diagram update
I just want to make everyone aware if you buy a Delphi fuel pump for your primary tank with the fuel gauge sending unit .....the color coded pigtail for the flat plug 4 wire plug update ( original is a square plug) is incorrect....if you splice your harness wires color by color match ....it will not work !
The black and grey are the pump wires
The orange/blk and purple are the sending unit wiresNow ...the black harness wire goes to the far left pin
the grey goes to the far right pin
The other two go in the middle two pins and it doesn't matter which middle two you pick
No one even Delphi or just answers had the true answers...not even Chevrolet as they said oh well it's a Delphi ..lol
I spent two days messing around till I figured this out correctly
Hope this helps someone .
Delphi FG 0275 fuel pump
Old Jul 31, 2022 | 7:46 AM
repairman54's Avatar
Another reason for another $30 you get the Genuine GM pump module and not have any issues.
I'm sure you would have gladly paid that to avoid the aggravation.
Old Jul 31, 2022 | 8:05 AM
Philgav's Avatar
Absolutely...but every dealer and part store had a week long back order on this part ...I needed to get up and rolling ....this shortage thing is a pain in every business these days
Old Sep 22, 2022 | 9:00 PM
Atom's Avatar
Default Help
[Are you looking head on or overhead?
QUOTE=Philgav;481043]I just want to make everyone aware if you buy a Delphi fuel pump for your primary tank with the fuel gauge sending unit .....the color coded pigtail for the flat plug 4 wire plug update ( original is a square plug) is incorrect....if you splice your harness wires color by color match ....it will not work !
Delphi FG 0275 fuel pump[/QUOTE]
monkey23
Jan 3, 2013 8:18 PM
monkey23
Dec 29, 2012 9:34 AM
jwsimiskey
Oct 21, 2012 10:18 PM
treasurehunter01
Jan 11, 2009 11:33 AM
Daryl1970
May 12, 2008 5:38 PM
