disconnet battey - help
Old Jan 1, 2011 | 9:52 AM
vrso2's Avatar
Default disconnet battey - help
Hi,
I'm about disconnect battery because my clock is not working on DVD/NAVI unit, but i found this article about it and now am scared
...... Here is a short list of some of the problems that can occur when disconnecting or replacing the battery on the following vehicle applications (refer to the OEM service literature for specific model and year applications and cautions):
Chevy Tahoe Loss of voltage to the vehicle electrical system causes the 4WD module to go to sleep permanently. The module never wakes back up when power is restored, and the only way to restore normal 4WD operation is to replace the module with a new one (a repair that may cost you over a hundred dollars!)....
Is it true or false ???
Old Jan 1, 2011 | 2:12 PM
I've replaced batteries in a 2004 and a 2007 w/o detrimental results.
Old Jan 2, 2011 | 9:13 PM
The vehicle modules will go through a learning curve after power is restored.
You should drive the vehicle long enough for it to warm up and drive it like you would at a brake in period, meaning drive normal, no hard accelerations, avoid high speeds and hard stops for a drive cycle..
You will probably have to program your clock and maybe your radio stations...
You can get a settings keeper that plugs into the cigarette lighter and runs off a 9v battery to keep the radio and clock memory...
Old Jan 3, 2011 | 1:14 AM
vrso2's Avatar
well, the reason, why i wanna to cut power is, that my clock doesn't work. I cant set time. All i see is separation dots. I was about to "reset" the radio that way
Old Jan 3, 2011 | 7:54 AM
SabrToothSqrl's Avatar
Default well
how are you attempting to 'set' the clock?
I think you just press the clock to set it.
Old Jan 3, 2011 | 8:42 AM
vrso2's Avatar
absolutely
Menu button, clock (top right):
All i see is separation dots, set for minutes and hours + and -, and 12 or 24 hours show.
Is there something, i don't do right ?
I tried to unplug radio for 10-15 min. but when i put it back, there was all like before. Looks like radio have own backup battery.
I dont know what to do. My last chance is this : https://chevroletforum.com/forum/sho...77&postcount=4
Or, do you have any advice ?
Thx
Old Jan 3, 2011 | 9:34 AM
ousig2408's Avatar
when I replaced out battery the radio stations were all still there and at 1st the clock was not set but it set itself somehow after a few minutes of driving to the exact right time?
Old Jan 3, 2011 | 10:20 AM
vrso2's Avatar
hmmm, my radio wont set ;(
Old Jan 3, 2011 | 4:00 PM
I suspect that instead of a battery, it has a non-volatile memory that stores all of the station presets.
Old Jan 3, 2011 | 9:27 PM
MDTAHOE's Avatar
Professional Mechanic
In my old Tahoe the radio was out for 4 years. When I traded it in I put the factory radio back in and all the stations were still there.
