DISK READ ERROR- Help!
Old Apr 19, 2012 | 1:41 PM
95z115's Avatar
Default DISK READ ERROR- Help!
I have a 2008 Chevy Tahoe and when I put a music cd into the music drive of the navigation unit, it reads "DISK READ ERROR"
The CD is a music cd, is clean, and not burned.
Any ideas how to remedy?
Old Apr 19, 2012 | 1:51 PM
15 Year Member
Try a CD cleaner disk.
Old Apr 19, 2012 | 2:12 PM
Are you putting it in to the correct slot? Reason I ask is you said navigation unit, not radio or CD slot....
Old Apr 20, 2012 | 11:43 AM
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> 95z115,
Do any CD's work? What color is the back (opposite side of the label) of the disc?
Louis
GM Customer Service
Old Apr 21, 2012 | 10:40 AM
Try the CD in another player to make sure it is a good CD and plays.
Old May 9, 2012 | 10:50 AM
95z115's Avatar
Hey guys I the CD back is silver, and it was an original copy, not a burned disc. I also tried several music cds. I also tried a disc cleaner and that did not work. I have accepted the fact that it is not repairable.
Thanks for your help!
Old May 9, 2012 | 11:54 PM
It is repairable. Is it worth the cost or should you buy a new one? If you can take it apart yourself and look at it, it might just be a broken belt. If the belts are good, the part can be replaced.
Uplander
Uplander
Jul 9, 2016 2:09 PM
txgearhead
Nov 20, 2013 10:47 PM
Chuck It
Feb 25, 2012 1:07 PM
Chuck It
Feb 23, 2012 11:52 AM
wheresgeorge
Avalanche
Jun 8, 2008 7:19 AM
