Uplander 2005-2009
Platform: U-Body
dvd - disk format error message
Old Nov 4, 2012 | 11:24 PM
Uplander's Avatar
Default dvd - disk format error message
We bought a used 07 uplander and dvd player did not work. The rear speakers also did not work when playing the radio via dash controls. Tonight while cleaning, I pulled the dvd player off the ceiling thinking maybe a dvd was stuck in the player. Found the cable was unplugged! Plugged the cable in and put back dvd player on ceiling. Turned on van to see what happened and quickly saw lights on the dvd player! Unfortunately, I ran the battery down by having doors open and interior lights on.
We jumped the van but had trouble. First, it honked when turning the key to start, then van started flashing lights. Finally, we got the van started and let it run for 5-10 minutes.
The dvd lights came on, so put a dvd in it. Dashes started going across screen, saw the play button, then Disk Format Error flashed on screen. Put dvd in right side up and upside down but it gave same message. Tried 4 other dvds, one copyrighted 1999 but could not get any to play and got the Disk Format Error each time.
Strangely enough, a CD will play in the dvd player but could not advance through songs. Button acted like it didn't want to work. Back speakers also work now!
Tried to check to see if dvd format is set to PAL or NTSC(?) but menu button doesn't appear to work. Other buttons do work on dvd player except intermittent problem with titles.
Checked fuses and they are good.
Could the low battery and problems charging the van cause problems with dvd player? Someone said to turn radio off, disconnect battery, wait 1 min., reconnect, and turn on radio. Scared to try for fear will need a code for radio to play and don't have.
Any ideas on dvd player fix would be great. Thank you.
Old Nov 6, 2012 | 5:17 AM
Uplander's Avatar
Default Static
We finally disconnected the battery but it did not fix the disk format error. It now has static in the screen and is hard to read. Any ideas?
Old Nov 7, 2012 | 10:12 AM
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> Uplander,
The Disc Format Error message will display if a disc is inserted upside down, if the disc is not readable, or if the disc format is not compatible.
If you continue to experience this issue, I recommend having the vehicle inspected by a certified technician for additional assistance. They will be able to provide more information, and repair possibilities, after inspecting the vehicle.
If you need assistance finding a technician near you, please PM me your zip code.
Louis
GM Customer Service
Old Nov 9, 2012 | 8:08 AM
Uplander's Avatar
Default Disk Format Error
Louis,
Thanks for you input. I would like to see if I can check the disk format settings to see if dvd player is set to PAL or NTSC. How can I do this? When pushing the Menu button, nothing happens. Thanks.
Old Nov 9, 2012 | 1:45 PM
kevinkpk's Avatar
Do you have the owners manual? It probably covers the player in it.
Old Nov 9, 2012 | 2:35 PM
I looked through the service information I had available and searched and only came up with this for the 07 Uplander
Check your RPO build codes in the glove box for the following, there is no guarantee thou they are listed I don't believe it is a user definable setting, it comes from the factory set... If you found something disconnected I suspect it was broke and someone else was also trying to fix it and gave up...
VFF
Video Format - Region 1, NTSC
VFJ
Video Format - Region 2, PAL
VFM
Video Format - Region 4, NTSC
Old Nov 12, 2012 | 8:09 AM
Official GM Rep
Louis,
I would be happy to look into this further for you. Would you please provide you VIN, so I may continue?
Louis
GM Customer Service
Old Nov 15, 2012 | 2:38 PM
Uplander's Avatar
Default Format Code
The dvd code is VFF, so that looks like it should be right if the player wasn't switched out. The VIN is 1GNDV33187D164602. Thanks.
Old Nov 5, 2014 | 5:47 PM
curtisparker82's Avatar
Default disc format error
I have the same problem I've tried using a laser cleaner with no luck. Used canned air no luck...any help.
Old Jul 9, 2016 | 2:09 PM
luzania's Avatar
Good afternoon!
Solve the problem? I appreciate if there is a solution, thanks!
08LT
Uplander
10
Jun 4, 2018 1:24 PM
95z115
May 9, 2012 11:54 PM
Chuck It
Feb 25, 2012 1:07 PM
Chuck It
Feb 23, 2012 11:52 AM
