Drivers Seat Dead in the water.
Old Jun 4, 2021 | 4:26 PM
BerserkerJack's Avatar
Default Drivers Seat Dead in the water.
K, So about a year ago, My 2005 Suburban 2500 4X4 w/8.1 had a lil hiccup. Drivers side seat lost power and wouldn't move. Was stuck "ALL THE WAY FORWARD" And then miraculously, outta the blue, I tapped the toggle one day and it maneuvered flawlessly. Cut to last night.......I accidently hit the "seat memory 1" button, and bam! Seat scooted forward, (all the way forward), and wha-lah.......stuck again. All fuses good. I thought it might be the motor, but there are several...... all dead. Even the lumbar, .....whole seat dead. Any ideas????? Is there a common thing with these seats being ..."(all the way forward)"???
Old Jun 4, 2021 | 9:45 PM
try holding the switch in the rear position and tap the forward/backward seat motor with a steel bar...if the seat moves....you need a new motor...the motor brushes are worn.
Old Jun 7, 2021 | 11:22 AM
Yeah, that was one of my initial thoughts, (like a starter on an old International Scout I once had, you had to tap it with a hammer now and again) 😏 But on this thing, the WHOLE SEAT is dead. None of the motors are doing "anything"....Seat won't slide, back won't recline, lumbar stuff won't adjust ........Nuthin.
Old Jun 7, 2021 | 4:34 PM
remove the seat cushion cover and foam pad...then you may be able to access the frame to floor bolts or seat motor
Old Jun 7, 2021 | 4:38 PM
Main seat motor is right up front ...... Super easy access.
Old Jun 7, 2021 | 5:07 PM
if none of the motors work ..did you check for power in and out of the switch
Old Jun 7, 2021 | 5:26 PM
There inlies my issue. Which switch? Each seat function has its own switch ....... All dead. But the fuses are all good, and the main power going "into" the seat is good. I just don't know where the power is going after getting in. That's why im here ..... Seeking any knowledge on a possible "common issue" prior to simply taking the whole seat apart and poking around lookin for a short. This is the 2nd time this happened, both while the seat was all the way forward. Starting to think something of the electric nature is simply caught up in the track.
Not being too lazy to do that first, it's just that im one of them disabled Marine Vets, (helo crash), and my head, back, heart, lungs, and knees don't dig on a bunch of crawling and bending. So I'm here hoping to find that others have had this issue and searching for an easy fix
Not lookin like that's gonna be my route though.
Old Jun 7, 2021 | 5:54 PM
do you have memory seats or w ithout
an3 is the build code located in the glove box build sheet. need to know what you have as an3 uses a seat module.
Old Jun 7, 2021 | 7:42 PM
Yes on the Memory Seats. Don't know about the build sheet. (don't understand completely what you are asking. I think "auto correct" might be screwing with your typing).
Old Jun 8, 2021 | 1:02 AM
The build sheet lists all of the RPO (Regular Production Option) codes on the truck. I would check to see that you are getting 12V at the seat switch.
