Engine won't run-Idiot lights off
Old Mar 20, 2011 | 11:19 AM
legolas894's Avatar
Default Engine won't run-Idiot lights off
I took off the instrument panel to find that there was no bulb in the ABS slot which explained why that light never came on during start up. When I put it back on, only the PRNDL light comes on and the vehicle won't stay running (it turns over but dies when you let the key back to run). Did I activate the security system by taking the gauge cluster off??
Really frustrated.
Old Mar 20, 2011 | 1:12 PM
EinST's Avatar
It sounds like the Gauges fuse 4 in the I/P fuse block blew. Maybe there's a short near the ABS lamp socket?
Old Mar 20, 2011 | 3:42 PM
legolas894's Avatar
You were right on. Fuse 4 had blown and I took the socket for the ABS off for now.
Thanks! I was worried I killed something.
Old Mar 20, 2011 | 6:06 PM
EinST's Avatar
Glad to hear you got it running. Thinking bad thoughts about whoever it was that "fixed" the problem last.
Old Mar 21, 2011 | 6:11 AM
legolas894's Avatar
It makes you wonder since this vehicle had a safety inspection before I bought it and the ABS light would have been on (if it had a bulb!!!). I guess it would be a lot to remove the dash to see if all the bulbs are actually there.
idsinteriors@srt.com
Jan 16, 2014 4:20 AM
klutz1
Oct 6, 2010 9:58 AM
bo0g1e
Mar 7, 2009 9:33 PM
OnDaGround
Jan 9, 2009 3:56 PM
