Erractic fuel gauge
Old Sep 1, 2014 | 11:00 AM
turbowrenchhead's Avatar
Default Erractic fuel gauge
I just picked up an 01 Suburban 1500. The fuel gauge is erratic. Does the cluster rebuild usually take care of this? Also my oil gauge vibrates.
Old Sep 3, 2014 | 3:06 AM
Sledgehammer's Avatar
With the 95-99 suburbans usually it is the sending unit that goes out as the ground gets corroded in the tank. Or the stepper motor(or something like that) could be the issue
Old Sep 3, 2014 | 4:56 AM
intheburbs's Avatar
It is a common issue, and it is usually the stepper motors, and a rebuild usually cures it.
I went a step further on my 01. Instead of a rebuild, I bought an HD cluster, which includes the trans temp gauge.
Old Sep 3, 2014 | 5:28 AM
I would say it is your sending unit in the tank. There was a problem with the stepper motors but that did not come up until around the 2003 models.
Old Sep 4, 2014 | 9:23 AM
A sending unit is cheaper then a cluster rebuild but much more time to replace and I hate pulling gas tanks.
I would have to send my cluster in for a rebuild and I would have to drive my vehicle without one while it was out. I'm wondering if the truck would run with no cluster. I don't see why it wouldn't. The cluster is just outputs so it shouldn't effect the truck.
Since I can't get a definite answer on this issue I think I'll order up a sender and pull the tank. Then I'll be able to move the sender while plugged in and see if the gauge still acts up. If so I'll put the new one in.
santa6
Jun 23, 2013 2:14 PM
hfdff
Jul 26, 2010 9:09 PM
scottkern3
Dec 7, 2009 7:53 PM
whit
Aug 14, 2009 9:04 PM
wrxsubaruwrx
Dec 3, 2006 12:33 PM
