evap module 2004 Z71
Old Nov 18, 2008 | 11:13 AM
freddyp's Avatar
Default evap module 2004 Z71
My 2004 Z71 sub is coding probleems with the evap - it list 3 problems - either the evap canister (cant find it but its supposed to be behind the gas tank), evap sensor or a connection problem. Is there anyway to check the problem without actually trial and error by replacing then sensor , then later the evap if the sensor isn't the problem
Old Nov 19, 2008 | 7:48 PM
jkgray80's Avatar
Default RE: evap module 2004 Z71
Whats the code(s). Common problem w/these is water/excessive dirt accumulation in canister. Requires vent solenoid replacement (theres an updated one for this reason), vent tube cleaning & canister inspection for water/excessive dirt. If canister is full of dirt or water you have to replace it. Canister isbehind fuel tankmounted on crossmember. Tube runs from vent solenoid into canister. Or it could be as simple as a crapped out fuel cap. Whats the code!?
Old Nov 19, 2008 | 8:08 PM
jkgray80's Avatar
Holy crap, sorryabout the huge pic.
malglot
Sonic (Aveo)
15
Apr 6, 2025 1:33 PM
pjm333
Aug 19, 2015 3:40 PM
Jerryny1953
Sep 29, 2013 10:44 AM
ps56k
Jul 2, 2013 1:36 PM
DanBrewer
Jan 2, 2007 2:54 PM
