Factory Trans cooler install
Old Aug 26, 2010 | 1:14 PM
  #11
ousig2408's Avatar
do you always leave in 3 and tow/haul? I thought if you are using the tow/haul you can leave in regular drive and let the computer shift the way it needs vs keeping it out of OD also. thanks for the update - let us know what the temp looks like when driving normally on the highway for a while
and yes only 83...finally! the 105+ for weeks straight was getting old, it is about 90 up here in Dallas now
Old Aug 26, 2010 | 1:27 PM
  #12
Yes I do tow in 3 and tow/haul enabled, it seems to be a lot less stressful on the tranny and keeps it from constantly having to shift out of OD every time I hit a small incline. It also seems to keep the trans fluid temp down when towing in 3.
Here a couple of points in the Onwers Manual on Tow/haul
"The Tow/Haul mode works with the Autoride®
feature, if the vehicle has this, to enhance the ride
when trailering or with a loaded vehicle."
"Your vehicle has a Tow/Haul mode. The selector
button is located on the end of the column
shift lever. You can use this feature to assist when
towing or hauling a heavy load or if there is a
need to charge a battery installed in a trailer."
"You can tow in DRIVE (D). You may want to
shift the transmission to THIRD (3) or, if
necessary, a lower gear selection if the
transmission shifts too often (e.g., under heavy
loads and/or hilly conditions)."
Tow/Haul Mode
Tow/Haul is a feature that assists when pulling a
heavy trailer or a large or heavy load. The
purpose of the Tow/Haul mode is to:
• Reduce the frequency and improve the
predictability of transmission shifts when
pulling a heavy trailer or a large or heavy load.
• Provide the same solid shift feel when pulling a
heavy trailer or a large or heavy load as when
the vehicle is unloaded.
• Improve control of vehicle speed while
requiring less throttle pedal activity when
• Increase the charging system voltage to assist
in recharging a battery installed in a trailer.
Old Aug 26, 2010 | 1:34 PM
  #13
ousig2408's Avatar
interesting, I have not towed much and the only vehicles I have used did not have tow/haul so we just put in 3 and went on.
what are you RPMs on the highway when going 60 mph in 3 and tow/haul?
Old Aug 26, 2010 | 1:49 PM
  #14
If I recall it bumps the RPM's out about 300 to 500 rpm's
On our trip to Yellowstone in June, towing the trailer, I'd say my MPG dropped about 1-3 MPG towing in 3 depending on terrain... over all I think I got about 17mpg... I always did 5 to 10 mph below posted to keep from having to pass folks and not play the leap frog game on long stretches...
Old Sep 8, 2010 | 10:25 PM
  #15
jac6695's Avatar
Any chance you have the part number for the kit? I can't seem to find it on GM Parts Direct.
Old Sep 9, 2010 | 5:37 PM
  #16
Its listed under the "accessories" tab
part number for the 5.3 2007 is 19171483
19171483 Transmission Cooler Recommended for Trailer Towing Upgrade w/ 4 Speed Automatic Transmission (w/ RPO Code M30, M70, w/o RPO Code Y91)
Old Sep 16, 2010 | 12:26 PM
  #17
GeeDubb's Avatar
Default Nice write-up and pix
I've got an 09 burb with the 6-spd auto, gmpartsdirect shows the same kit #19171483 but description is for the 4-spd. Does anybody know if this kit will fit the 09 Suburban?
Gary
Old Sep 17, 2010 | 9:17 AM
  #18
Your parts man can look it up and tell you. Or you can try gmpartsdirect.com.
Old Jan 18, 2014 | 11:03 PM
  #19
Tony_V.'s Avatar
Nice write up.
Old Jan 19, 2014 | 2:07 PM
  #20
Welcome to the forum Tony_V.
