Factory Wheel Cleaning Methods
Old Jan 24, 2015 | 8:20 PM
cerobbins's Avatar
Default Factory Wheel Cleaning Methods
I have the factory finished GM wheels on my 03 Z71 Tahoe.
I haven't been able to get them looking like new in years.
I usually clean them with purple stuff and a bristle brush. This has always worked fairly well, but there are a few stubborn spots typically in corners and crevices that just will not go back to a factory new look with this method.
I assume I need to do some type of polishing with an abrasive compound of some type to really bring these wheels back to a like new clean but I've always been hesitant as I'm not sure what is safe for the finish that GM puts on these wheels.
I'd had a hard time finding information on the finish they use and safe methods to really clean it.
I also have a few scratches on the face of one wheel from getting stuck years ago that I would like to attempt to repair.
If anyone can point me in the right direction with either item I would be very appreciative.
-cerobbins
Old Jan 25, 2015 | 2:11 PM
I had brown brake dust discolouration on my rims that I could not remove. Scrubbing methods were tested in small area but left marks. A detailer at work used a diluted acid etching solution designed for cleaning rims. She power washed the rims, sprayed on the solution and let it sit for 1 minute. The rim was wiped off with a rag and then power washed off. Show room condition when done.
Old Jul 9, 2015 | 8:34 PM
hipyhipe's Avatar
I usually use Chemical guys diablo wheel cleaner with daytona brush to clean it perfectly. For tough stains I use Megs wheel cleaner but depends on the wheel finish.
scott_mckinney
Jul 4, 2007 2:27 AM
bradstump
Sep 21, 2006 10:42 PM
