Fan not blowing from front vents
Old Sep 16, 2021 | 4:39 PM
mmartin611's Avatar
Default Fan not blowing from front vents
2010 LT 1500 suburban, after traveling 30-45 min the blower will cease blowing and roar, if on high. Rear system works fine. Next day, sometimes even the same day it starts again. I’ve seen videos on filter and blower fan, but any suggestions on what could be the problem?
Old Sep 17, 2021 | 7:33 AM
repairman54's Avatar
Is this happening with the a/c on in high humidity ? Evaporator may be icing up blocking airflow.
Old Sep 18, 2021 | 7:29 AM
mmartin611's Avatar
Not high humidity and usually on high as it’s been 80+ the last few months. As stated, starts 30-45 minutes into trip.
Old Sep 18, 2021 | 10:12 AM
+1 for icing. is the system overcharged causing evaporator flooding? If you home charged the system...its probably overcharged. You need to charge by weight not a pressure gauge.
beaseac
Dec 22, 2019 11:54 AM
Kenneth Miller
Jul 12, 2016 9:32 PM
jmpretty
Uplander
May 1, 2014 1:50 PM
Vega Wagon
May 8, 2012 5:36 PM
towinnh12387
Feb 2, 2011 10:33 PM
