first Tahoe ! , problems need advise on my 2000 please
Old Jun 27, 2006 | 10:51 PM
houszton's Avatar
Default first Tahoe ! , problems need advise on my 2000 please
i just bought my 2000 checy Tahoe LS and it came with a few problems first off the daytime running lights dont work and also the enmergency break cable it broken *** well , But my main consern it the A/C in the front works but when you are running down the highway it blows air with the air seystem off ' as if u still had it on number one setting but the comppressor is not running ' any advise please im a picky guy as we all are and its driving me nutts just knowing it has these problems ,, ALso as a first time chevy owner i would like to know any heads up anyone might have for me to know ahead of time as in problems it might hasve or what to exspect thanks for any help i might get i would apreciate it greatly e mail me if u know anything at housztonblue@yahoo.com
Old Jun 28, 2006 | 12:55 AM
viperjuice's Avatar
Default RE: first Tahoe ! , problems need advise on my 2000 please
hey there, by 2000 tahoe i'm thinking it's the one with the 5.3L,
as far as the air blowing, that is normal. As you drive, the air gets forced into the cabin. The doors don't shut when you shut the blower motor off, they go into default and there will always be some air flowing past the blower motor. Other wise you would suffocate by not having fresh air.
As far as other prblems on this truck, if you have a rouch idle when cold you will need intake gaskets
if you have an extended crank, you will most likely need a fuel pressure regulator. You can tell if it's bad by taking the vacuum hose off of it and see if there is fuel inside or it smells like fuel.
On occasion the extended crank is caused by the fuel pump going bad and returning fuel pressure to the tank so it has to start from scratch when you try to start.
front axel seals seem to leak on those.
and i think that those are the main things. Good luck with the chevy
[IMG]local://upfiles/1535/CEA95057325D41A8855AF3A19DB18081.jpg[/IMG]
[IMG]local://upfiles/1535/DA977569F3A44E609818511A6F5AB4F3.jpg[/IMG]
[IMG]local://upfiles/1535/DD79F514E5524976A2DEFF6B916C45C3.jpg[/IMG]
[IMG]local://upfiles/1535/F4E5AB53BBC04239A5F7BA1D4BB4A1DB.jpg[/IMG]
Old Jun 28, 2006 | 5:41 AM
houszton's Avatar
thanks for the quick replie and yes it is a 5.3 ............ also i had ahnother question im not sure but i think i also have a littel hasitation when i give it WOT , and also i noticed a littel bit of wetness on the driverside carpet the coolant level seems to be fine and holding and i dosent smell like antifreez so i dont think its the heater core
Old Jun 29, 2006 | 9:36 PM
viperjuice's Avatar
well it takes them a few seconds to down shift, but try cleaning your throttle body, a far as the wetness dude. go fish.. sorry nothing typical on them,. and if it was the heater core, it's be on the pass side and you'd smell it.
Old Jul 6, 2006 | 1:15 AM
fastblueheeler's Avatar
HAd the broken emergency brake cable on my 2002. This was in 2004. I never use the e-brake so I found out about it when it failed state inspection. Fixed at dealer for about $200 BUT we were pissed since we never use the thing. Wrote a letter to GM, they reimbursed the repair cost. It's apparently a common problem. You might check this out.
Old Sep 3, 2006 | 12:10 PM
smokestack04's Avatar
For the daytime running lights press and release the dome light over ride button four times real fast. should turn them on.
Old Sep 3, 2006 | 12:55 PM
uncle bill's Avatar
The failure on running lights seem to be a problem. I've seen many with only 1 working or none at all. Tje water on passenger side carpet is from a clogged a/c drain. Cleat it out so the water will drain outside of the cabin. I think the other problems have been addressed by other posts.
Old Oct 6, 2011 | 10:02 PM
mmitzman's Avatar
Thank you viperjuice. Ishould have read this blog yrs ago. Had extended crank and rough idle since I bought my Tahoe, swapped the fuel pressure regulator, idles smooth and starts right up. Dealer said problem was low battery. So much for dealer mechanics.
Old Oct 7, 2011 | 12:42 PM
mmitzman Welcome to the forum
Cali504
Aug 22, 2013 12:53 PM
kimmer71
Dec 30, 2012 6:14 PM
fyrcaptain
Oct 6, 2009 9:15 PM
pat130
Jun 11, 2007 5:00 PM
houszton
Jun 28, 2006 7:33 PM
