Fluids for 07 Suburban LT 4x4
Old Nov 18, 2010 | 5:57 PM
8rings's Avatar
Default Fluids for 07 Suburban LT 4x4
I'm getting some conflicting sources on the required fluids for the following components. I am getting ready to make these changes and want confirmation that these fluids will be correct:
Front Diff: 80w90 with GL-5 (doesn't have to be synthetic)
Rear Diff: 75w90 Synthetic
Transfer Case: Auto-Trak II (another manual says to use Dexron VI ATF)
The vehicle is a 07 Suburban 3LT 4WD.
Thanks.
Old Nov 18, 2010 | 7:20 PM
I'd go by the Owner's Manual. Or ask the service dept if still unclear.
Old Nov 18, 2010 | 9:06 PM
Should you not have your manual available...
Attached Thumbnails Fluids for 07 Suburban LT 4x4-capture.jpg   Fluids for 07 Suburban LT 4x4-capture2.jpg
Old Nov 19, 2010 | 9:52 AM
Zed 71's Avatar
That's what I used for my 07 Tahoe. Keep in mind it may be different for the Burb if you have the heavy duty version especially for the transfer case. The transfer case has the part number on the rear and mine was a New Process (NP) brand. Like others suggested, check the manual and discuss with service department. I would also suggest a Hayes type manual.
I just did mine and those fluids were dark.
Old Nov 19, 2010 | 4:04 PM
8rings's Avatar
Well those are from the manual but the Haynes shows ATF in the transfer.
I purchased the above fluids today along with some coolant for the a flush.
Thx.
Old Nov 19, 2010 | 7:27 PM
I got a Haynes manual for my Corvette and after 30 years, I still haven't found a good use for it. Maybe if I ever go back to using charcoal instead of propane, it would make a good fire starter.
IOW go by the manual or your service dept.
Old Nov 19, 2010 | 8:39 PM
Factory manual hands down the winner, why have almost good enough, pretty good or almost just like it, when you can have it exactly....
cidsamuth
Feb 24, 2012 9:49 PM
technicauto
May 4, 2011 5:14 PM
brewder
Oct 19, 2010 3:01 PM
cowboyfromhell
Jun 5, 2007 9:31 AM
partsfor24
Apr 18, 2007 3:55 AM
